TomBishop
hi everibody, I'm Alessandro from Italy and my Crossfire Coupe '05 has the same problem. I add that I have the same problem always when it rain. I changed the CPS but i didn't solve it. Now I will try to check the RCM.
Any Other advice? I'm desperate for 2 years.
My Crossfire die when it rain
Two places you might check one is in the trunk or you might call it the boot , check the central locking mechanism under the mat on the passenger side and see if it is wet, also check the floor board on the passenger side and see if it is wet, if either or both are wet then there are multiple threads that will tell you how to deal with both. Just use the search bar.
