IAT at 95C with new IC pump! How to test?
Hi everyone,
So I read a quite a few threads (some of them are epic sagas) about superchargers not engaging and loss of power on the SRT-6/SLK32. I am having the same issue, sadly, and am at my wit's end on this. The symptom is familiar, but after trying almost all the things I have read here, I still am losing power. Here are my symptoms:
Supercharger clutch disengages after warming up, mid-throttle, about 30 seconds of constant boost later, it cuts out and Priuses pass me with no problem.
My car is a 2002 SLK32. It has the NeedsWings DCAI, 178 pulley and PSK, along with a Eurocharged tune and an Eisenmann exhaust. These mods were all done years ago and have had no issues until now for some reason.
My Relay Control Module had been modified by Tighed1 years ago and I have a brand new spare also that I have swapped back and forth to test with.
Here's what I have done recently to try and fix this issue (in chronological order):
1. Replaced IC pump (old pump was a CM30 that I had installed 4 years ago). Replaced it anyway with a new CM30. Resodered connections and heat shrunk wires.
2. Installed NeedsWings Coolant Iso Kit. Ran it through a heat cycle and closed the valves.
3. Tested the car, same issue. SC disengages half way home every time after about 30 seconds of mid-throttle uphill at about 50mph.
4. Checked all fuses under the hood and in the dash. Replaced Intercooler pump fuse (5a) with a new 10a fuse just to be sure.
5. Replaced Intake Air Temp sensor with new OEM from dealer ($50). Changed out the Relay Control Module (K40) with a brand new one.
6. Connected my tablet to the ELM427 bluetooth OBD2 adaptor and ran a real-time IAT reading for my next test
7. Intake air temp readings (with new sensor) show 27C cold, slowly warms up to about 50c, then uphill climb it increases 95C (200F)! At 95C the SC disengages the clutch for safety. I remind you this is mid-throttle, normal city driving, nothing out of the ordinary.
8. Limped home, IATs started dropping. At 70C the SC came back.
9. Came home, let the car cool down, checked all fuses under the hood and in driver's side dash area again. All are visually good as far as I can tell.
From what I can tell, the SC is functioning as it should, and the ECU is telling the clutch to disengage for safety, like it is supposed to. My issue now is why are my air temps coming in at 95C? I have a NeedsWings DCAI, the ambient temp today is 67F, which is chilly for SoCal standards! So I've decided that the pump isn't even running at all (despite being new) which means no power getting to it, hence checking and rechecking all the fuses.
Now I'm not an electrical guy nor am I super comfortable probing meters and paper clips into fuse areas or anything, so I'm kind of at a standstill.
Is there an easy way for me to send DC current directly to the IC pump (preferably from under the hood and not having to get to the pump directly?) I read on this forum to jump the left side of fuse 13 and 14 with a paper clip or a DC amp meter but on the fuse chart those two fuses on my car state they are for the "diagnostic socket" and "soundbooster"???
After reading Sweet02's saga thread completely many times hoping to find something I haven't tried yet, the only thing I can think of is maybe reflash my ECU (I do have an Eurocharged tune) but that has worked for me since 2010 with no issues and has never been reflashed since it was done, so I can't see how it can be a software glitch like he described how he solved his issue eventually.
I do have a multimeter but don't really know how to use it. The needles are too large to put into the fuse blocks to test anything.
Any suggestions at this point would be greatly appreciated!
Thanks
