Old May 12, 2016 | 11:37 PM
amx1397
Default Re: IAT at 95C with new IC pump! How to test?
due to the use of the c30, i assume you had to wire in the pump,, so maybe the pump is running backwards, it would still work and circulate the water , it would just go backwards through the intercooler and have more heat that way.. just reverse the wires on the pump and make sure that is no it. jim
