Old May 13, 2016 | 05:32 PM
MB04XFIRE's Avatar
MB04XFIRE
Default Re: Won't turn over fans come on??
Hi Tighed,
I've been having that issue with driving and the car would just stall.. Then I would try and start the car again thereafter and there was nothing.. Starter not engaging and the fan would go on if I would leave the key in the on position.. Wait 5 or 10 or 15 minutes and then the starter would engage again and good to go for a while.. Til it would just shutoff again etc.. I'm just worried it won't start up at some point at all and will be stranded somewhere... I've soldered the Rcm but didn't see any solder joints that were bad.. I also changed the crank position sensor yesterday too.. Haven't gone out for a spin with it since as I am now putting in my CAI..
I've read that this symptom could also be the crank sensor? Is this correct or is it definitely the engine control relay in the Rcm?
If so which is the engine control relay in the bank of relays in the RCM?
Thanks in advance.
