Old May 13, 2016 | 07:01 PM
onehundred80
Default Re: No interior or trunk lights
Originally Posted by BibaResto
I finally mastered the little tricks for removing the four separate connectors. Best I can see is that the interior couldn't look much newer. It would be great to know which areas apply to the dome/cargo lights. But also should the 'connections' for the electric spoiler be included. The M-B # for this pump is 1708000848.
I don't know if this is a big deal or not, (battery is disconnected) but I just got continuity on one of the female pins on the small black connector. I will say that the connectors appear to be clean, but feel a good blast of high quality contact cleaner might help.
Unless there are 'things I can do', other than use contact cleaner, I'm guessing this is as far as I can
go.
Is it possible to hook this back up with the lid off and see what happens when you lock doors, open the locked car with the fob and not open a door for 20 seconds and watch it lock up again. Maybe see if any thing moves when you shut the door and open them, maybe something is not turning on the lights and the reason can be found. Also put the lights on and open and shut the door to get the fogs lighting and going of by the timer, I an sure the timer is in this security module.
You would have to sit in the car and peek over the back or look through the hatch glass.
This would be first for this experiment and worth writing up.
