Old May 14, 2016 | 11:46 AM
DTMenace's Avatar
DTMenace
Default Re: Headlight Restoration
Originally Posted by ZX2 Nick
Does anyone have a recommendation for Headlight Restoration?
I mean a product or kit that has worked well to fix the surface flaking that seems to be normal on Crossfires?
My car has flaky, etched looking areas on both headlights. There is no "yellowing". It seems to be an environmental plastic corrosion issue.
Nick
I've used Meguiar's headlight refurbish kit that includes, sand paper, Wool pad for a variable speed drill, Plastic X, micro fiber towel. You should use a spray detailer to "wet" the headlight surface before and during the process.
Meguiars also sells a UV polish to retain the new look for a longer period of time. For best results, read the instructions or go to Meguiars website for this procedure.
It works great, if done properly.....
Dennis
DTMenace
