[QUOTE=ROB311952;866338]
RED DOG
The MAP sensor is mounted to the bottom of the intercooler which is mounted underneath the supercharger. Not easy to get at and almost impossible to change without removing the supercharger. I seriously doubt that is your problem unless you are getting a trouble code that indicates to look at the MAP sensor circuit.
Well, I hope it isn't my problem but I am getting P0135 which is the MAP circuit. I'm going to change the plugs and wires tomorrow as it's just about to hit 100K miles. I will check all my electrical plug connections and look for any leaks.
Well today I erased the code, and installed a dozen new NGK Iridium plugs and Bosch wires. While I had things apart, I checked all the vacuum and electrical connections I could get to, cleaned the throttle body and the K&N filters. Tightened up a few fasteners here and there as well as clamps. Had to remove/replace the belly pan to retrieve the sockets, etc. I dropped doing all this.
Cranked her up, and the idle speed had gone back up where it belongs and idling smoothly. Took a for a ride making a quick stop then quick start which was causing it to stall before. This time pulling hard and smooth with no jerking like before, and even broke the tires loose on a rolling start with no hesitation. Glad I don't have to deal with a MAP sensor replacement after hearing I would have to remove the supercharger for that! You'd think they could have used a little plumbing and found a more accessible place for it. Anyway, now 99,600 miles and counting.
Next on the list is replacing the turn signal/multi-function switch which has become intermittent.
