Thread: RCM relays
Old May 16, 2016 | 08:11 PM
kingdavid54's Avatar
kingdavid54
Default Re: RCM relays
Originally Posted by Rob M
I thought the same at first; thinking that a no start with crank would be the result of the fuel pump relay not enabling the fuel pump to operate thus starving the engine of fuel. However, if the fuel pump relay malfunctions to the point were it won't close at all, the PCM disables the ignition/starter so you get no crank. The engine control relay, when closed, allows the PCM to communicate to the fuel injectors to deliver fuel. If it is not operating properly, the engine can still crank, and sometimes even start but once it malfunctions the fuel injectors won't get the current they need to work.
I think you just explained my problem
{ fuel pump relay not closing causes the PCM to disable ignition/ starter causing no crank when key is turned to start.}
