Power steering reservoir o-ring leak often?
Shop says I need a new pump. It did not leak before I had them change the oil. Is this no-ring a common leakage issue? I'd rather try a $5. fix if it is common rather than a new pump. From what I see one bolt and the o-ring itself must hold the reservoir in place, is this correct? Thanks
