Re: ESP/BAS Light code C1210
NPB CROSSFIRE
Well finally got light to turn off. I bought cheap rf wheel sensor on Ebay for $15 MISTAKE since I wasn't sure that was the fix. It caused code reader to throw about 10 codes not related to problem. When pulled it out you could see it was touching hub. So found an original used one and put that in. Light still on ,code reader still had code C1210 but this time said [Fault indictor light on. test drive.] So drove it a couple times no change so decided to check fuses, I pulled numbers 17 and 18 waited couple minutes put them back in and now light is finally off.
Edit: Sorry, didn't know "Launch Creeder" was actually the name of the code reader.
Reason: Answered own question
