Thread: no electrical
Old May 19, 2016 | 12:58 PM
crossfirelady's Avatar
crossfirelady
Default Re: no electrical
Gotta be battery, battery cables/terminals - or something that Iv'e never seen before: The 200 amp fuse in that little box is loose or internally bad. I just don't see how you can loose all of THAT any other way.
Well, if the nut is loose on the TB strip at the back of the underhood fuse box (Driver's side, it's UNDER the fuses, you pry up hte front of the fuse panel, pull it up and out, and the distribution strip is at the back of the box. There are, I think, three junction points with all connductors held tight by a nut). But again, never heard of them coming loose but you never know.
I just don't see any other way.
I can your point; it's hard to imagine what else would cause the lost of all power. I'll be running a trace of the positive and negative cable back to their end point to make sure nothing is loose.
