Thread: no electrical
Old May 19, 2016 | 01:07 PM
crossfirelady's Avatar
crossfirelady
Default Re: no electrical
We have seen cases where the battery cables have failed inside the insulation.
How long have you had the car, how old is the car, the mileage, how old is the battery and is there any sign of corrosion on the cables where they exit the post clamps?
Can you get the battery tested? I had a battery fail in less than two years this winter while it sat in the garage. I doubt it is the battery really.
I may change the cabling just in case; based on what your saying.
I have had the car for 5 years now; it's a 2005 crossfire with a little over 100,000 miles. the battery is 6 months old and I did change the terminal clamps when I got the new battery, so no corrosion there. But you could be right about the cable (specifically the negative cable)
