crossfirelady
I may change the cabling just in case; based on what your saying.
I have had the car for 5 years now; it's a 2005 crossfire with a little over 100,000 miles. the battery is 6 months old and I did change the terminal clamps when I got the new battery, so no corrosion there. But you could be right about the cable (specifically the negative cable)
You said you changed the terminal clamps when you put a new battery in, I would pay very close attention to where the cables go into those clamps and check to make sure they are clean tight and making good contact, I don't trust those aftermarket clamps it is best to only use battery cables that are soldered to the clamps. When I was much younger I put a set of those on a Mercury Cougar that I owned, I thought they were tight but ended up melting the negative post off the battery because they were not making good contact. I learned a valuable lesson from that and have never used them since.
