Old May 20, 2016 | 10:54 AM
JEFASOLD's Avatar
JEFASOLD
Default Re: Engine Belly Pan
Originally Posted by bucketlisted
I pulled the belly pan on my newly acquired xfire to change the steering stabilizer and also to take a look at the underside condition.
On putting it back last night I noticed that the two rear screws would not tighten down without feeling stripped.
I took a look up in the threaded hole and it sure sure does look like machine threads and not acceptable for the metal screws that I took out.
Anyone know what type and size screw for those 2 rear screws?
If I can't get any info, i'll just drill and tap to a #6 or #8 thread and go get a couple fender washers
Also the front center hole(s) is missing a fastener, I used a moulding clip and sheet metal screw with fender washer.
]Something tells me that another type of fastener is used there, can you guys shed some light on this before I button it all up and bring the car back to earth, thanks
The two fasteners in the back are the same as the front ones. The one in the middle is a push pin type.
