Old May 20, 2016 | 07:00 PM
  #4483 (permalink)
Power Sedan's Avatar
Power Sedan
Had a 5 hour window of free time, so I went ahead and changed plugs, wires, and most importantly, the new Needswings Teflon coated valve covers and SS hardware. My oil leak was on the drivers side, not just the breather covers, but 3 separate leaks around the gasket as well, which I believe was due to improper torque on the valve covers. It kept dripping onto the exhaust manifold. Looks much better! I'll have to do some test runs, just make sure everything is good, then onto the passenger side, which doesn't leak.
Plugs were definitely due! 12 years, 40k miles
Since I had the belly-pan removed, I did a little TLC to it as well.
