Thread: no electrical
Old May 22, 2016 | 10:12 PM
crossfirelady's Avatar
crossfirelady
Default Re: no electrical
Originally Posted by kingdavid54
You said you changed the terminal clamps when you put a new battery in, I would pay very close attention to where the cables go into those clamps and check to make sure they are clean tight and making good contact, I don't trust those aftermarket clamps it is best to only use battery cables that are soldered to the clamps. When I was much younger I put a set of those on a Mercury Cougar that I owned, I thought they were tight but ended up melting the negative post off the battery because they were not making good contact. I learned a valuable lesson from that and have never used them since.
So update, I have checked all wiring and followed advice and swapped for soldered clamps. and and cleaned any connections I thought suspect.
However now I'm getting a hesitant start; like multiple cranks before initial start..
