Thread: no electrical
Old May 30, 2016 | 04:09 PM
crossfirelady's Avatar
crossfirelady
Default Re: no electrical
Hesitant starts can be a symptom of the lack of fuel. After you leave the car off for awhile and then turn the key to the on position, before the start position and leave it for a fifteen seconds with just the fuel pump humming and then try to start it, does it fire up and keep running OK?
If so then that may well point to fuel pump or fuel filter problems.
@onehundred80 - I did as you said and found that the engine does turn over with less hesitation when I let run for 15sec before trying to start. I would like to change the fuel filter first, but do not know where it's located. do you have location and steps?
Also, does the crossfire only have the one fuel filter?
