Old Jun 1, 2016 | 01:22 AM
latemodel21's Avatar
latemodel21
Default Re: SRT6 dies; BAS ESP light when accelerating
Originally Posted by IsaacF
So the throttlebody itself may not be bad, but just some connections?
This (bas esp and limp to stop) happened on both my sons SLK32 and my SL55 more than a few times. In both cases, the throttlebody was not bad, it was the connector on the harness plugging into it. Later mercedes models actually had a short (male/female) extender harness that came glued into the throttlebody (presumably to seal/immobilize the connection). You may get away with merely cleaning the connector with a good contact cleaner (part of the mercedes service procedure for the TB IIRC).
it would most often happen after some hard acceleration (on more than one ocassion, I had just passed a line of cars on a winding road then crapped out and I had to roll to a stop looking like a D-bag).
On both cars, I tried cleaning the connectors and they would eventually fail again.
On my sons SLK32, I replaced the harness from from the ECU to the TB and the problem went away.
On my SL55, I added the male/female extender harness and the problem went away. (I was actually using it as a troubleshooting step as I expected the problem to persist and I could isolate it to either the harness connector or the TB .... but the problem went away and I left the extender harness in place)
I have the part number for the extender harness somewhere ($50 IIRC) and I also have part numbers for the housing and pins for a DIY re-connectorization ($12 or so I think)
hope that helps,
Chris
