pjs626
Had the car 3(SRT coupe) weeks and it will not start. Started her up on friday and ran it about 10 min. I wanted to take it out but it was wet and she was still clean.
Today I go to try and start the car and the starter kicks in but she won't start. This happened 3 x and then nothing on the starter. I check the forum and start playing with the RCM. My friend is an electrician and car knowledgeable so we start checking all the fuses and checking the relays on the RCM. They all seem to be working but the engine just won't turn.
Finally I suggested to disconnect the battery to see if it some how resets itself. Again it turns over fort 3 starts then nothing. Lights are on, no bad battery and all fuses are checked for continuity. Disconnect again and 3 attempts then nothing.I did this procedure a few times hoping it would start. I had the car towed to Chrysler and now it is out of my hands.
Anyone have any such issues? ARGH
Sorry to say but you should have come here first before taking to the dealer now it's out of our hands also but, here's a suggestion whatever they tell you at the dealership do not give them the go-ahead until you come here to The Forum first and tell us what they found, not trying to be An A- hole just trying to give you the best answer based on your circumstances. Dealership is Probably going to tell you that it is the skreem module but that may or may not be the case, even though the starter engaged three separate times and then locked out the engine never actually started and ran and then died did it?
