Old Jun 9, 2016 | 04:39 PM
onehundred80
Default Re: P0140 & P0341/Prior Service Work Issues/RCM Fix
Originally Posted by bodhijames
Both sensors showed up - (thanks again for the links)
and I have my E8 socket ready.
I would rate my car wrench skills at average at best (on a good day). Any "gotchas" to look out for?
I read in one thread the plug can be tricky to get pulled off. Any tips?
I'll use some contact cleaner on the contacts. Plus take a look at the two pins in the plug.
I'll be extra careful starting the screw (by hand) once I get the camshaft sensor replaced as to not mess up the threads.
Any other advice or encouraging words before I pop the hood tomorrow?
Thanks
The CPS can be removed with the cable still attached, the plug is easier to unlatch this way. Be careful not to drop the little bolt, some use some method to get the bolt to stay jammed in the socket.
