Old Jun 11, 2016 | 06:31 PM
Reevz1977's Avatar
Reevz1977
Default Re: Air Con Growling
Or if you wanted less work you could remove the cabin air filter under the dash and vacuum out that area. You can see the fan blades there. Usually it gets leaves and twigs in there, even if it does not solve the growl the area will have been cleaned.
Where would that be located?
Many thanks
