Old Jun 14, 2016 | 06:04 PM
BibaResto's Avatar
BibaResto
Default How to remove lower bolster...
...on the driver's side dash? I noticed that there were two (amazingly) phillips head screws. So how hard could it be? I removed the screws but the bolster seems as if it is glued in.
Is it a pressed fit and needs lots of pulling from underneath?
I need to install a largish switch and need to see if there is room for it.
What is inside the plastic gizmo under the steering shaft? Just curious. I removed its cover in case there was a fastener for the bolster.
