Old Jun 14, 2016 | 06:43 PM
onehundred80
Default Re: How to remove lower bolster...
Originally Posted by BibaResto
...on the driver's side dash? I noticed that there were two (amazingly) phillips head screws. So how hard could it be? I removed the screws but the bolster seems as if it is glued in.
Is it a pressed fit and needs lots of pulling from underneath?
I need to install a largish switch and need to see if there is room for it.
What is inside the plastic gizmo under the steering shaft? Just curious. I removed its cover in case there was a fastener for the bolster.
If you use SEARCH and type in BOLSTER you will get this thread CLICK.
Go to post #70 and read on.
This is not the first time this has come up, use search as it is your friend.
