How to remove lower bolster...
Valk, thanks for the 'how to remove the bolster' write-up and photos.
As it turns out if I mount the switch on the bolster area, there isn't enough room behind for the switch, housing, contacts, and female spade connectors. The area of the bolster most likely I'd use (directly under the ignition switch) is about 1 1/4". I need 1 5/8".
So my question is there enough additional room behind the main housing (roughly) 1/2" in the area below the ignition switch? (Ummm, it just occurred to me that position is just about where my knee would land if I slid under the three point belt in an accident. That's about where it hit in a long ago crash in my Alfetta GT).
As long as I'm rambling, are there any good + contacts (need two) in the very general area of that switch position?
A photo of that area with the cover off would be great.
