Old Jun 16, 2016 | 01:12 PM
kingdavid54's Avatar
kingdavid54
Default Re: No Crank Condition Plus Other Issues
Originally Posted by Rob M
In the end the issues with my original RCM related to the transmission, speedometer, and various brake/traction control MILs were solved by replacing the traction control relay. Engine would still not crank and continue running until I cleaned the contacts on the engine and fuel pump relays. So, at some point I will likely need to replace those relays as well. For now the RCM works fine and I have also procured a spare.
Thanks for your reply and I'm glad you got it fixed.
