Old Jun 16, 2016 | 10:44 PM
Rob M's Avatar
Rob M
Default Re: Headliner Removal
forum member onehundred80 has put together a pdf with instructions to remove the headliner:
https://www.crossfireforum.org/forum...placement.html
it's a bit tricky but not too difficult. you have to bend and manipulate the headliner board a little to get it out the passenger door - your headliner was originally installed through the hole that was later filled by the windshield. getting some of the clips out and back in successfully can try your patience as well. If you do it yourself try to make sure your dash is covered with a sheet or something similar to avoid scratches - especially to the soft trim above the instrument cluster.
you are unlikely to have much success attempting to re-glue the headliner, especially from an aesthetics standpoint. The foam backing is deteriorating, and anywhere you attempt to reattach will be noticeable. Not to mention, other parts of the headliner that are currently attached will gradually start to sag as well. You really need to remove the headliner, clean off all the foam backing, and use a suitable high-temp adhesive to attach new headliner material to the board. You can do this yourself [I redid mine, it came out so-so in some of the corners/curvy areas, so it's on my list of things to (re)do - but the replacement material is adhering well after several years]. Or, just take it to a pro and have them do it. You can save some $ on replacement cost by removing the headliner and reinstalling it yourself if you are fairly handy and careful. there are some good you tube tutorials that provide instructions for applying new fabric.
