Old Jul 14, 2006 | 07:18 PM
woody's Avatar
woody
Default Re: Just built my new ECU
Originally Posted by intenseblu
ooh i got one tid bit of info for you for when you go with the 7th injector part of the project...
make sure to use the dual table code to run the 7th injector... the standard code injects fuel even if the VE map is set to 0% across the board cause it still takes cold accel enrichment into account amongst other values... the dual table code was designed to run progressive nitrous control, so 0% means 0 pulsewidth no matter what...
Thanks for that Intense. I'm a little way off running the extra injector (or anything else for that matter!) as I am still wiring up the loom and need to get the plate machined. I am going to run the MS on top of the stock ECU (i.e. all the inputs connected but not the injectors) to make sure I am getting clean trigger, TP, MAP and temp signals.
