Re: Key fob replacement case...
I cleaned it with 99% rubbing alcohol and a q-tip. It didn't remove all the corrosion and I quit rubbing it with the q-tip when I seen some green of the board flake off. It is now working fine, 3 chirps lock, 1 chirp unlock. Should I take it apart and use wd40 on it?
