blackpepper
My car is running a little slower than normal I lost around 5 mph in the 1/8 an the 1/4 ,I think my belt is slipping causing doing a burnout I don't get that belt squeal anymore after I stop ,and the manifold gaskets haven't been changed in four years,I think that is a place to start oh boost gauge indicates 19 psi with a code three pulley so I know that's code use to indicate 17.5
I don't get that belt squeal anymore after I stop do u get the belt squeal during the run?
have you done the throttle reset?
when you last ran was the temp as hot as it is this month?
19 lbs of boost sounds like what the code 3 can put out.
try to add about 2 gal of 100 octane gas to just under 1/4 tank.
mph can also be lost by tire spin at the line. did the et drop?
