deltacrossfirebob
I finished replacing the hydraulic cylinders on my top. Had great help/advice from Klauss at Top Hydraulic and gr3 here.
My problem now is that the trunk does not open with the top down, and the top does not always operate on demand.
I have double and triple checked all the connections that I messed with. The switch on the divider is taped closed and I put the divider in correct position.
Any advise greatly appreciate.
Thanks
If you haven't already done so, remove the
electric trunk lock actuator. Go to post 122 in this thread
https://www.crossfireforum.org/forum...-jammed-3.html
