Re: Front Anti Roll Bar / Swaybar bushes
I have had the brackets off several times which hold the sway bar bushings. Both the fit of the bushing inside the brackets and the bushings relative to the sway bar itself is tight. It would be a job to slide the OEM bushings off the sway bar and slide new bushings back on because of the tight fit and the fact that the bushings are rubber.
