Re: Confirmation that no exhaust/header is avail for SRT-6
The car does have an intercooler. Using larger more efficient cores is going be a little work. Basically the route you are going to have to go is to purchase a set of laminova cores, remove the SC, bore out the existing cores to the new size and install.
If you want to try and use a larger radiator for the intercooler system you will need to watch pressure drop.
