Old Jul 2, 2016 | 01:13 PM
GraphiteGhost
Default Re: Flashing fog lights
I think these lights flash when the alarm goes off, if they do then check out the following.
Look for water in the trunk well that houses the CLP/SSM, it ruins the pump and controls of the security system. Check it out, look for water down beside the foam blocks underneath the trunk mat.
Originally Posted by srt10
For some reason my fog lights on my 2006 coupe start flashing. Once I turn off the alarm system they stop flashing. This has occurred twice in June. Someone told me it could be the front SAM. Anyone aware of this issue? Thanks
Does the alarm siren sound when the alarm is triggered? Besides the excellent advice Dave (180) gave here, you should also make sure your siren works. If the alarm was triggered and only the fog lights are flashing, then your siren may be toast as well. Finally, are you near an extremely high RFI (military or defense contractor) location? I ask this because my fog lights went off by themselves (no siren activation and my sirens work great still to this date), when a B-1 bomber was buzzing the local Air Force Base. I posted about this weird event a long time ago, and another member in the military (If I remember correctly, Guam) had the same thing happen to him. It never happened again to the best of my knowledge. This Air Force Base does not host B-1 Bombers (Shaw AFB) as a rule, they just visit once in a while.
