Old Jul 15, 2006 | 06:36 PM
bengel's Avatar
bengel
Default Re: went to the track today with the srt-6
the calculator is set up for a near perfect run under near perfect conditions, as well as optimum gear ratio. Gear ratio is not all that important in drag racing as long as your not running a 2.73. alot of guys still run powerglides with only two gears and the most common is about a 4.11 rear gives you a great et but you might run out of rpm if you can't rev your engine that high.
