Old Jul 8, 2016 | 06:58 PM
onehundred80
Default Re: Non-tpms valve stem size
Old thread, never answered? Did a search but could not find this answer. What is the TPMS stem hole diameter in the rims (for replacing the TMPS with a standard rubber stem). The new rubber stem will 'PoP' into the rim hole, so it must be the correct diameter to seal the hole throughout its whole hole diameter (pretty good wording there, huh?).
Initial search has the hole at .453 (11.5mm) diameter, it is the same size on all wheels for cars. The fact that it has TPMS makes no difference.
You can fit TPMS in any auto wheel, trucks use .625 diameter holes.
