Thread: 65mm to 62mm
Old Jul 11, 2016 | 11:27 AM
Zoodust's Avatar
Zoodust
Default Re: 65mm to 62mm
Originally Posted by Morphh
What answer with fuel mods for the 62mm pulley on a c32
I personally belive you need a new fuel pump at minimum as well.. i ran a 65mm for years and then switched to a 185 pulley(which makes same as the 62) and i run 550 injectos, 55 fuel pump, and a retune.. some even add a looped fuel rail as well.. if you stay with stock fuel on 20+ psi that is not wise
