Old Jul 18, 2016 | 02:45 PM
stevedask's Avatar
stevedask
Default Re: NEED Drive SHAFT Center Support (bearing?)
Originally Posted by dinasrt
No press required. Remove and replace.
So Mechanic says buy the needswing support & Bearing part and he will put it in but he said he is not sure if he would need to get it sent out to rebuild or if it's a 2 piece driveshaft he says then it can probably be replaced at the shop?
I confirmed it's a 2 piece driveshaft in our cars and I see dinasrt said just you just remove and replace it so is that like a simple 1 hour labour job if I supply the part?
Is this a repair I can do in my driveway with an intermediate auto repair knowledge & tools?
Thanks
