Re: NEED Drive SHAFT Center Support (bearing?)
Wow - so I can just jack the car up and take off a few bolts -slide out the old part and to replace the support/bearing - for some reason I was envisioning some elobrate drive shaft removal and dissambly that had to take place with worrying about balanceing of the shaft etc.
Assume the flex plates are just removal of a few torx bolts, drop out old plates and put new in as well?
I can definatly manage it if it's that simple. Or at least know that the repair shop should only be charging me about an hour of labour.
So to confirm I don't have to worry about any balancing of the drive shaft or lining anything back up - just slip on the new parts and bolt it back up?
