I have a 2005 Crossfire SRT6. It was damaged on the driver's side. To do the repair, panels that are spot welded and glued need to be removed. Is there a way to remove/dissolve the glue so that the parts can be taken off?
thank you,
Drill out the spot welds and heat the bonded area. I am not sure how much heat is required though.
