deltacrossfirebob
Thanks for all the advice and help.
Have removed the electric trunk lock actuator and have taped the divider switch closed.
Still having problems...
Thanks
Just a thought (they randomly occur)...when you say you removed the electric trunk lock
actuator...you removed only the black hickey on the end of the white plunger, correct?
Removing the whole thing or even leaving it disconnected would cause the car to assume
that no signal from the solenoid is bad news and shut everything down.
As I said...just a thought. Wish I had the ability to help you more.
