velociabstract
I don't know. However, once I had my brake system and ABS module "professionally" bled and they couldn't get a firm pedal. I didn't think much of it until I activated the ABS at the racetrack. The next corner I tried to brake and pedal went to the floor. I drove 100 miles with almost no brakes (carefully) before arriving home. I don't think the module cycled. To get the air out of the ABS module I had to activate it repeatedly (concrete floor) and bleed the system afterwards. It took several sessions to finally get all the air out and a firm pedal.
Les
When I changed the brake fluid I wondered what special steps had to be taken with regard to the ABS and the Service Manual said none. I think that no oil sits trapped inside the unit, all the fluid is on the one side of the unit, the same side as the fluid in the lines. The pistons control the volume of system, if you get what I am saying. I can see you getting air in the unit, that is why the reservoir has to be kept topped up. The individual brake lines go to the ABS unit and are treated individually in it. There is no reservoir in that unit, just ins and outs and the pistons.
