moparmanpr
oil level is below the bottom of the dipstick.
Use the following procedure from the Owners Manual to see if the oil level indicator is working properly. You should see a recommendation from the warning sensor on how much oil to add to the engine.
And as we've stated earlier, monitor the oil for several days/weeks to see if you're losing oil. You say your warning light is on. With the dipstick showing oil below the LOW mark, it is suppose to be on!
Sorry - went back & read your original post again. I'd agree with
onehundred80, most likely a malfunction in the oil level measuring system. That's why they gave us the "old tried & true dipstick" as a backup for measuring oil level.
I'd be adding oil to get the dipstick level back in range. And I'd recommend paying a lot more attention to the oil level in your Crossfire!
