Old Aug 5, 2016 | 12:19 PM
crosscats's Avatar
crosscats
Default Re: Gearbox speed sensor (P0500)
The speed sensor is mounted on the electrical plate located just above the sump pan. Remove the pan, remove the plate and replace the sensor if required.
Or you could do as they say for thousands of pounds more. LOL
I'll see if I can find a picture of it.
What codes are being set, find out before spending any money.
Thank you - will get the other codes from the garage.
Their code readers would not give enough detailed info so they took it to the Chrysler main dealer for clarification.
The yaw sensor was also suspected at some point...
OK, in addition to P0500, we have C1120 & C1142 (latter subject to confirmation)
C1120 seems to relate to gearbox speed sensor.
Failing that, they say the next thing to check will be the yaw sensor.
