P0410 / BAS/ESP Etc.
Just had to say thank you to this Forum. I hope all folks concerned will see this THANK YOU. Sunday went for a little ride with the wife, maybe a total of 20 miles. On the way home the Check Engine light came on. The car seemed OK so continued home. Hooked up my OBDII and checked codes, YUP, the dreaded P0410 I went through the site (search) and came across what might be causing the code. I tried resetting the code and it did reset. I had purchased a used RCM awhile back and sent it to DJ for the FIX and the "Me So Horny" up grade. I was not having any problems so I put this in the car for later. Well, for me, later was here. Went back into the site and checked out the best/safest way to make the change. DJ came through again. NOW, after making the change, connecting the battery back up, I got a BAS/ESP light. NOW WHAT. Well, back to the site, found, through search how to reset that light. SO, folks,
once again, THANK YOU, you folks are great. OH, I will send my original RCM to DJ to have it checked out and up graded. SHORT SHORT money for piece of mind.
Bill T.
Reason: Changed No to So Horny
