crazyfred
What would the procedure be to do the reset?
Thanks in advance.
Not positive if it is for an SRT-6 but here it is copied from 180's list of documents.
Throttle Reset
From the original post by danimal on 08-15-2006
1. Get in your car, it doesn't matter if you close the door or not.
2. Turn the key to the on (not start) position.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
5. Wait 2 minutes for a full alignment.
6. Drive the car as you always do. In short;
Key on, pedal down for 5 sec, key off, pedal up, wait 2 minutes. Keep the key in for the entire thing.
Copied/Pasted from the .pdf, credit given in text and here!
