Old Aug 23, 2016 | 07:05 PM
onehundred80
Default Re: Knock sound when turning car off
You know, the fan motor/blades/housing is an assembly - why not just replace it?
I am 99% sure this fits - maybe 100/80 or Mr. Miata can verify.
Mercedes C280 99 00 SLK320 CLK320 98 04 AC Radiator Fan | eBay
The fan and motor and the shroud are only an assembly when fitted together, they can come as two separate parts although they could be sold as an assembly with the use of some other parts.
You can buy the fan and shroud separately.
The SLK320 and SLK32 quote different parts to what is on my Crossfire. The shroud is a different number altogether and the fan is #000 540 15 88 and #000 540 16 88 on the SRT I have.
I believe the NA and SRT use the same fan and shroud - I'll check though.
Look at the parts on your cars the Mercedes part number is on most parts, even those made by Bosch etc
I got the SLK320 and SLK32 parts list in the documentation thread along with other lists but why did I bother if nobody looks at them. I admit they may get out dated in a few places but the basics are there.
