Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Relieved!!! Just Finished version 5, Sticky Key probably a day away from being stuck for good. I used a spare key left in the ignition for a few days until I had time to fix it myself (It takes 35 minutes after you exit the vehicle until you can use a second key to lock the car using FOB, my manual key doesn't work) Risky but as long as it's temporary weigh the options of getting stuck by removing the key or leaving it unlocked for 35 min. The PDF was super! First fix that went without a hitch! Barely cursed and finished under 2 hours! Everything works as it did before the sticky situation. I didn't have to drill anything, just removed the spring and button located under the thin metal tab. Thank You very much for a detailed & updated DIY!!! Huge Relief! 2004 XFire Limited HardTop Owner since 07'
