Old Aug 26, 2016 | 12:59 AM
onehundred80
Default Re: Water in the trunk/hatch
Originally Posted by Scalawag
I'm sure it is on here somewhere, but the search turned up nothing substantial. I found standing water under the foam supports under the hatch. Quite a bit actually. After pulling everything out, I found and pulled the plug in the bottom. I really want to find where it came from and fix the problem properly. Has anyone had a leak in the back and figured out where it came from?
Using advanced search and looking for posts not threads gets a lot of answers, 'Water in trunk' gets the answers.
For the SRT this is one of them. CLICK
The NA leaks at the same panel as the SRT and the drain hoses going from the wing depression to the bottom side if the hatch can suffer from the hoses leaking by getting damaged.
