Wheel specs:
ADR M-Sport
18 x 8.5 front on 235/40/18 Continental Extreme Contact (.3" taller)
18 x 9.5 rear on 275/40/18 Continental Extreme Contact (.7" taller)
No spacers in the front, 20 mm hubcentric spacers in the rear. Needed shorter bolts up front and longer in the rear. Also had to clearance some of the upper ball joint bolt end in the front to prevent tires from touching.
Here is a better side shot:
