Old Sep 2, 2016 | 08:04 AM
  #1033 (permalink)
KDW4Him's Avatar
KDW4Him
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by ffmdicpete
Well it isn't fixed, I still get the three strikes and you are out. I thank you for the reboot information as I have had to use it a couple times. What I am wondering is if I buy a new circuit board my problem will be solved??????????
And I see it was running on 8-28 "I bow to your wisdom, intellect and kindness for having patience with a newbie. It fired right up but I must say I don't have a lot of confidence it won't quite again. Go big or go home. Heading to the store with it. I guess I need to just get back on the horse.
Again, thank you.
Pete"
By three strikes and out are you referring to the car cranks but doesn't start three times and then never cranks again?
I don't recall you mentioning that before, that is the SKREEM module, RFID chip in the FOB or antenna ring issue. Totally different symptoms then the relay module no crank. Odd you have it running on 8-28 but now have SKREEM issues. Have you done the sticky key repair and not put the antenna ring back on? This is a common missed step, making sure the antenna didn't get pulled from the SKREEM.
You mentioned door lock issues, were you diving into the dash behind the instrument cluster? Door remote is SKREEM related, you leave something disconnected?
